AEMV2 and AEMData logs into VirtualDyno
Old Aug 29, 2013 | 09:53 AM
herecomesboost's Avatar
Default AEMV2 and AEMData logs into VirtualDyno
Has anyone successfully loaded an exported csv (text format) into virtualdyno using an AEMData file? The exported csv doesn't appear to include a 'Time' column by default (which is a requisite parameter for virtualdyno). TIA
Old Aug 29, 2013 | 02:00 PM
liquid_helix136's Avatar
Yea you gotta export the datalog as an RTF file. CSV won't work with AEM.
Then when you go to load it up in VD, just hit view all types of files and the RTFs will show up.
Old Sep 3, 2013 | 04:45 PM
I appreciate the response, but the AEMData exports using a user specific delimiter. If you alias the parameter names in the virtualdyno software (ie. alias 'Time' to 'seconds), then it doesn't matter what delimiter you choose to use for the export (comma delimiter in the case of csv's and tab delimiter in the case of txt files).
turbo8765
Oct 16, 2012 10:47 AM
s2konroids
Apr 9, 2012 09:47 AM
osidis
Nov 9, 2010 10:44 AM
osidis
Nov 8, 2010 12:46 PM
sbrodacz
Apr 19, 2009 06:42 PM
