Another KPro AP1 question- "remove old crank sensor wiring"
Old Mar 26, 2011 | 06:50 AM
rwheelz's Avatar
Default Another KPro AP1 question- "remove old crank sensor wiring"
I am not sure if these instructions mean to just remove the old wiring that is attached to the timing cover up to the connector, in order to route the new sensor/wiring, or whether they mean to remove it more extensively. I know leaving the actual wire in place won't cause a problem, but am I supposed to be removing the pins at the ECU for the old TDC sensor and crank sensor? Will leaving them in place cause a problem? My intuition says no, since the Hondata is reading the new sensors from the other connector's pins.
EDIT: for anyone else doing the Kpro-into-Ap1 install, my friend/mechanic said we did NOT need to remove the oil pan and that it was a waste of time!
Old Mar 26, 2011 | 08:08 PM
rwheelz's Avatar
Well, it is up and running smoothly so I guess there is no need to remove any extra wiring or to de-pin at the ECU connectors!
Xeon
Dec 24, 2016 12:45 PM
crisskro
Oct 9, 2013 07:46 AM
crisskro
Oct 7, 2013 01:24 AM
03spa
Aug 2, 2010 03:31 PM
vadhert
Apr 26, 2009 09:13 AM
