The job of the TPS sensor
Old Dec 18, 2016 | 08:37 AM
Xeon's Avatar
Default The job of the TPS sensor
Hi guys what kinda of info does the tps sensor provide the ecu
what is the normal closed throttle position percentage on a stock ap1?
can a miscalibrated tps sensor cause the car to run lean/rich?
Old Dec 18, 2016 | 10:15 AM
Slowcrash_101's Avatar
Yes, but more likely an old O2 sensor, or old fuel injectors, rare that a TPS goes bad. It feeds voltage to the ECU like every sensor in the car. This one is a 3 cable, one is a reference voltage, one is ground one is signal. Nominal output is ~.5v at idle and ~4.5v at WOT, with smoothly increasing voltage as the TPS runs through it's range of motion.
Stop trollin'
Old Dec 18, 2016 | 08:05 PM
Xeon's Avatar
Stop trollin'
never really answer my question
Old Dec 18, 2016 | 09:29 PM
steelers743's Avatar
https://en.wikipedia.org/wiki/Throttle_position_sensor
there answered...that wasn't that hard was it
Okay that was harsh but you don't seem very thankful for someone trying to help you out for your vague question that doesn't seem like you did much research on first.
The TPS does just what it sounds, computes the throttle position , like just how he described so don't know how you cant say he didn't answer your question.
https://www.s2ki.com/forums/s2000-un...closed-567913/ found with a simple search
Originally Posted by S2Kart
Update: Yes, AP1 needs the TPS voltage to be at .48-.52V at idle.
And no I don't think it can, at least from my DBW perspective, all it does is compute the throttle position, if you are running lean/rich it is your fueling.
Old Dec 18, 2016 | 10:00 PM
flanders's Avatar
On stock ecu mine was at 5.5% when fully closed and 88% at WOT.
Old Dec 19, 2016 | 10:22 AM
Xeon's Avatar
Finally thank you
Old Dec 19, 2016 | 11:20 AM
flanders's Avatar
You can calculate percentage from the other answers as well.
0.5V would be 10% and 4.5V 90%
Old Dec 20, 2016 | 05:05 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you are trying to trace the one black spark plug, the tps cannot cause it.
Old Dec 20, 2016 | 08:14 PM
Xeon's Avatar
noi I am trying to make sure my ballade throttle body is set up right as long as the car drives right and does not rev hang it should be good correct?
Old Dec 24, 2016 | 12:45 PM
Soviet's Avatar
If your TPS is not operating correctly you will very likely get a CEL.
cdelena
Jan 23, 2016 08:34 PM
vadhert
Apr 26, 2009 09:13 AM
ack5252
Feb 19, 2008 12:50 PM
S2000AD
May 12, 2004 12:08 PM
hyperpm
May 15, 2003 05:36 PM
