apexi neo question
Old Jul 8, 2010 | 03:20 PM
josh7owens's Avatar
Default apexi neo question
I got my boomslang harress but I still haven't got the neo yet. I was going to go on and install the harness and wait on the neo. I plugged everything up and then started the car. the car ran for about 15 seconds and died. took the harrness off and pluged everything back up the way it was and it ran fine.
My question is does the neo have to be plugged in to run the car with the harness or is there somthing wrong with my harness (i got it used off here)
thanks,
josh
Old Jul 8, 2010 | 06:21 PM
josh7owens's Avatar
anyone?
Old Jul 9, 2010 | 05:12 AM
Gernby's Avatar
Former Sponsor
You cannot use the harness without the NEO connected, since the MAP sensor passes through the NEO. If the NEO isn't installed, then the ECU won't be able to read the MAP sensor.
Old Jul 9, 2010 | 04:02 PM
josh7owens's Avatar
ok thanks
AZ-S2000
Mar 23, 2013 05:13 AM
CTECHs2k
May 10, 2009 06:25 AM
jwa4378
Mar 28, 2009 02:10 PM
ap1chick
Oct 12, 2008 09:09 AM
NFRAP1
May 7, 2008 07:59 AM
