APP sensor replace or Flashpro to cure hesitation?
Old Sep 8, 2018 | 02:17 PM
ES2K's Avatar
Default APP sensor replace or Flashpro to cure hesitation?
My '06 DBW AP2 has always had the low rpm hesitation when accelerating from a stop (not reving and dumping the clutch). Been reading about people solving the problem by changing the APP sensor and resetting the ecu while others claim a flashpro tune is the cure. Has the sensor change to a new OEM unit been vetted as the fix? Will a flashpro tune of the throttle plate map provide a guaranteed fix? If I just want to improve throttle response and eliminate the hesitation, will a new sensor be enough? If I choose to go with a flashpro, is there any advantage to also replacing the sensor?
TIA
Old Sep 10, 2018 | 07:41 AM
T-Man's Avatar
I believe Gernby did a thread on this a few years ago but I was able to tune it out using Flashpro. As memory serves, there is a timing dip at high load and low rpm in the ignition maps.
Old Sep 11, 2018 | 07:08 AM
ES2K's Avatar
T-Man; thank you for sharing your solution.
Disgustipated
Jun 21, 2017 02:19 PM
joefish1298
Jul 20, 2012 05:57 PM
jason4207
Sep 2, 2005 11:10 AM
JohnE
Aug 10, 2005 08:20 AM
hyperpm
May 15, 2003 05:36 PM
