Basic question, Emanage Ult
Old Dec 3, 2010 | 09:53 AM
Olegator's Avatar
Default Basic question, Emanage Ult
If I turn all of the tumbler switches in off position(effectively turning off the ign and fuel adjustment maps), will I still have injector compensation active?
Old Dec 3, 2010 | 10:59 AM
Olegator's Avatar
Old Dec 3, 2010 | 11:13 AM
s2konroids's Avatar
That entirely depends on what you have set the jumper switches (maps) set to in the map settings.
Old Dec 3, 2010 | 03:22 PM
Olegator's Avatar
what do you mean?
"Switch on" set to "map active"
My question is if injector adjustment in parameters will be disabled if I turn the maps off by flipping all of the switches to off
Old Dec 4, 2010 | 09:36 AM
SgtB's Avatar
I beleive you can set what the switches do.
I doubt the injector offset will still be functional. A wideband will tell you instantly.
Old Dec 5, 2010 | 09:03 AM
urBan_dK's Avatar
Assuming you don't set any of your maps to use the switches, it doesn't matter whether they are on or off.
Old Dec 12, 2010 | 04:04 PM
Alloy Craft's Avatar
Former Sponsor
Injector timing is a engine parameter, and can not be tied to a switch. If all switches are off, it still uses the value you have for injector lag time.
Old Dec 17, 2010 | 08:14 AM
Olegator's Avatar
Thanks Alloy
Old Dec 17, 2010 | 08:16 AM
Olegator's Avatar
Does anyone know a good Emanage ultimate tuning forum?
I used to go to mhodparts but it is down.
Zuikan
Jun 4, 2017 08:19 PM
s2konroids
Apr 30, 2012 06:48 PM
chillout18
May 23, 2009 11:52 AM
Trip
Jan 13, 2006 01:55 AM
Reignman
Jul 31, 2003 11:52 PM
