Can someone look at my Datalog?
I am by FAR NO expert on tuning. I did however look through them and can definitely see some things that scare me and idk if its even safe to drive like this. Like I said im a total noob on this but I do plan on getting my car tuned by Evans in the next 2 months. If someone could please take a look at both my logs and give me a quick summary of what I need to do would help me out alot... Hopefully that will lead me to the next step and actually try and fiddle with the tune myself.
If someone has some free time I will email the logs to you. I cant upload them to this site for some reason so please please please someone just take 5 mins and help!!
I'm running TODA tune. Mods - K&N FIPK, Berk 70mm and FlashPro!
I just want to make sure its ok to run my car like this before I go get tuned because im worried when I see numbers in the red :| and I also have knocks that go up to 11...
The most knowledgeable person I know with datalogging and tuning besides evans is Gernby on the forum..I didnt run any base map at all due to the fear of causeing any type of damage to my engine but maybe I was just being over cautious.. My car knocked about 45 times on my first tune with evans lol From what I was told The Toda tune is great but very lean but im a noob just like you lol Just spend the 250 for an etune cause thats what I did and its totally worth it and safer
Merry xmas
Merry xmas
That's not true, there are plenty of other knowledgeable tuners on this forum including Brian, Wadzii, Timg, Jh4db and probably a couple others.
If you wanted to, OP you could take a screenshot of the logs in question and I'm sure someone could chime in.
From what I've heard, the Toda tune is pretty hit or miss. If your worried about it, can't you just unplug your flashpro and just run the stock ECU until you get it tuned?
4.5k vtec and 10hp up too isn't worth a blown engine
Hey I was actually lucky to have b.r.i.a.n. look at my logs ( THANK YOU!!) He claims everything looks safe. He knows more than I do and seems very knowledgeable about tuning.
Would it be bad to have a tp and intake on your car without a tune?
you can run a test pipe and intake on the base map. the closed loop o2 control will keep the afr's in check in the mean time but it could run lean full throttle depending on which base map you're running.
You can send me a log at matt@shuetuning.net . Its been my experience that hondata's basemaps are often way over advanced on timing. 11 knock count is not huge though particularly if it is only hitting 11 after multiple pulls.
Im going off of actual experience from dyno tuning. Not by what the timing values look like.
I dont remember how the s2000 maps look, but for some of their k series maps this has been the case.
yes they seem high on the k-series base maps but it is because of the knock control tables in the background also affecting actual ignition timing. for years those tables were not exposed on k-pro. they were exposed on the flashpro software first and then k-pro.
