E-manage ULT or VAFC
Old Mar 31, 2010 | 10:56 PM
SRap1's Avatar
Default E-manage ULT or VAFC
Im torn between getting an Emanage Ultimate and the cheaper VAFC. The price difference isnt that much if i get a used emanage. Which is easier to get a descent part throttle tune out of, and is this a EMU that most have problems with.
Car is a ap1, comptech non A/C stock 6# for know, but will be stepping up to the 10 # and aftercooler setup, (with larger injectors if i choose the emanage) or just the RRFPR and pull fuel with the VAFC.
Any advice is appreciated
Old Apr 1, 2010 | 06:04 AM
Gernby's Avatar
Former Sponsor
VAFC really isn't that helpful for FI applications, since they don't help you add fuel. They only help you remove fuel.
Old Apr 1, 2010 | 06:06 AM
Gernby's Avatar
Former Sponsor
Sorry, I should have read your whole post before replying. I see that you would use the VAFC with an FPR, but that is still an inferior setup than the EMU. Unless the cost difference is too significant, take the VAFC off your list.
Old Apr 1, 2010 | 02:38 PM
Kyushin's Avatar
Banned
You will regret the VAFC if you are boosted and going for 10 lbs. Do it right and get a standalone, larger injectors and a good tune. All it takes is 1 bad tank of gas to eat some piston rings or grenade you.
Old Apr 2, 2010 | 05:34 AM
scareyourpassenger's Avatar
Emanage ultimate will handle 10psi just fine with proper tuning.
Old Apr 2, 2010 | 06:14 AM
SRap1's Avatar
The emanage ultimate is just a piggy back right? thats what i want.
Yeah i realize now the highest i can go is 7psi with the stock injectors and the vafc to pull fuel below vtec.
But is the tuning fairly simple, i've never messed with tuning software really: though i've seen it displayed and the tuners going throuigh the motions when i got my turbo prelude tuned.
I know it needs to be at 12-12.5
and to pull around 1degree of timing up top per # of boost? (or until theres no nitceable knock)
But is it as simple as typing in numbers and it adds or pulls fuel?
Old Apr 2, 2010 | 05:41 PM
96-EJ6's Avatar
K-Pro and a good tuner.
Old Apr 3, 2010 | 11:29 PM
SRap1's Avatar
yeah i know thats the best way to do it and if i was in a place where i could get it tuned i would believe me, i have with my other cars, but im in a part of spain where i cant... besides i would like to attempt this
Old Apr 8, 2010 | 03:40 AM
myflys2k's Avatar
The emanage is pretty easy to tune to get the car running 90% but it takes someone that really knows the emanage to get rid of a couple small hiccups at part throttle (have very few now). If your choice was only between the emanage ultimate and the vafc2 then i would do emanage. You can adjust timing and add fuel without tricking the stock ecu by adjusting the injector pulse width. Not to mention static fuel pressure instead of using the RRFPR
SortaRican
Feb 9, 2012 08:38 AM
Snowmoto125
Feb 24, 2009 09:52 AM
nightcrawler7188
Jun 4, 2007 01:06 PM
03spa
Jun 14, 2004 02:22 PM
2_and
Jun 8, 2004 07:38 PM
