Emissions testing
Old Sep 12, 2013 | 07:38 AM
steelers743's Avatar
Default Emissions testing
This might be a stupid question or the wrong area. But I moved to VA from AL and to get the car registered here you have to do Emissions testing. I have never done one before or really know how it works.
I have a TP on stock exhaust and custom E-Tune done, I was wondering if anyone has ever passed an emissions test with a test pipe or would I have to install the cat back on. Also is there some way I can alter my tune to just upload to help lower the emissions reading during the test?
Or you all can just call me dumb Thanks
Old Sep 12, 2013 | 07:50 AM
thenoxus1's Avatar
I don't know all the VA law but usually its emissions and safety inspection. VA is strict, but for emissions its sometimes a visual check and they may tail pipe sniff it. Also they will check the OBD2 link to check all ready sensors/no codes actively thrown. Safety includes ride height, proper bulbs/equipment etc etc.
Old Sep 12, 2013 | 01:21 PM
1nate7's Avatar
It varies by state, you need to find specific information for Virginia. In AZ, it's a ODBII check only and as long as there is no CEL, you pass. You would fail any sort of visual or sniff test. It's very easy to swap a stock cat back in temporarily if you can't find any other way around.
Old Sep 27, 2013 | 06:54 AM
Jmays2k's Avatar
No there is not here in Tn the emissions arent that bad and I didnt pass and I put a bung with a cel delete and I still didnt pass
Old Oct 2, 2013 | 06:36 AM
Nand01's Avatar
Fouler if you have a CEL, (it will just space out the O2 sensor farther from the TP and wont read so high) but wont pass visual... I Say make a friend that owns a shop and will pass you.
kwin5946
23
Sep 1, 2012 03:39 PM
91crxdx
Mar 6, 2010 04:39 PM
BORT617
Jun 8, 2007 04:47 PM
SilverKnight
Jun 13, 2006 05:44 AM
Dolemike
Apr 19, 2006 06:18 PM
