Engine Problems
Old Jul 28, 2014 | 04:28 PM
iDomN8U's Avatar
Map sensor make sure it's connected well
Start there
Old Jul 28, 2014 | 11:46 PM
starchland's Avatar
When the problem occurs, does the engine rpm go up , stay the same , etc
Old Jul 29, 2014 | 01:16 AM
Belkin623's Avatar
I'm pretty sure it's what Feezy said: I'm not letting it warm up enough before I gun it. Rpm doesn't go up, it just shuts itself off for a second.
Old Jul 29, 2014 | 01:18 AM
Belkin623's Avatar
The grinding hasn't occurred as violently recently and the engine thing hasn't happened for awhile since I'm making sure it's warmed up.
What I'm concerned about now is the misfire since it's probably not just the coil pack, which I thought it was.
Old Jul 29, 2014 | 08:32 AM
S1AS2K's Avatar
if the valves were adjusted too tight it will cause a miss. ive seen this alot. if you have the means you can graph the map voltage and watch the waveform to determine if it's an electrical or machanical miss. a nice square wave pattern is an electrical miss and a jagged up and down(like a heart monitor) is a mechanical miss.
Old Jul 29, 2014 | 05:27 PM
starchland's Avatar
Nice work, never thought about that
acklavidian
Sep 27, 2013 04:50 PM
solidol
May 19, 2011 10:41 PM
why_2k
Jul 9, 2010 04:14 PM
rijowysock
Mar 17, 2007 11:29 AM
johnnydev
Dec 4, 2002 05:09 PM
