Flash AP1 ECU?
Old Jan 27, 2010 | 07:38 PM
B5254T4's Avatar
Originally Posted by DFWs2k,Jan 27 2010, 02:39 PM
why is KPRO weird?
a good tuner can utilize the e-manage with great results (Mase)
what about the Haltech?
Remove weird from my text and read the rest.
OBD functions with Haltech?
Old Jan 28, 2010 | 01:44 AM
scheister's Avatar
Yup, it is just a piggyback.
Old Jan 28, 2010 | 07:21 AM
B5254T4's Avatar
Great, didn´t know about that. Good stuff? Any members here using it?
Old Jan 28, 2010 | 09:34 AM
scheister's Avatar
I personally don't know what it is like, but yes there is someone running it.
https://www.s2ki.com/forums/index.php?showtopic=753559
Old Jan 31, 2010 | 11:16 AM
RStoR's Avatar
Here is a link showing how to chip an OBD2 ECU. It states it'll work on '96-01 ECU's. That covers OBD2A and OBD2B ECU's.
http://www.autoserve.8m.com/OBD2Emu2.html
Seems OBD2 ECU's use WORM (write-once read many) chips.
This was because there was no external prom for the fuel/ign tables. It was burned right into the main processor and this had to be done when the chip was burned, and could only be done once.
Old Jan 31, 2010 | 12:25 PM
B5254T4's Avatar
Interesting... I think Nissan S14 use the same technique and that´s why that extra PCB and chip needed to be added to the ECU.
The problem is to read the information when you´re in there.
Old Jan 31, 2010 | 02:16 PM
RStoR's Avatar
Techtom provides the chips I believe. Don't see a Honda application, but that doesn't mean there isn't one.
http://www.technosquareinc.com/index.html
Yoshio @ Japanese Automotive use to provide Toda chipped OBD2A ITR ECU's. They used a Techtom chip I believe.
http://www.japanese-auto.com/tuning.htm
May be worth inquiring with one of them.
Old Jan 31, 2010 | 05:58 PM
SgtB's Avatar
Honda went cheap on the AP1 ecu and used a non-flashable processor. The processor can be jumpered to read an external ROM, but rewriting the entire code externally is tricky with no notes. There is some interest in it on PGMFI right now, but it's a small group of people on that ECU. There is a 96k dump of the firmware, but it's binary code, and will take quite a while to crack. The current way of mounting the rom is a pogo board over the processor.
Old Feb 3, 2010 | 03:34 AM
B5254T4's Avatar
I´ll ask my buddy if he want to try it, he´s doing many other car brands.
Old Feb 3, 2010 | 10:55 AM
01BBS2K's Avatar
i was thinking about converting an s2000 to obd1 hahaha its cheap and works good.
