Flashpro
will a stock s2k with flashpro/hondata see any gains?
is it just for 06+ models?
Can we make changes with the flashpro that would equal the toda reflash for the 06+?
Is this unit superior or equivalent to a full Hondata ECU?
FlashPro
- $700
- Plug and play installation.
- All stock vehicle features work (cruise control)
KPro
- $1400 + cost of PRB ECU
- Installation uses dual adapter & stock ECU must be reflashed.
- Faster upload time.
- Many more features (Boost control, Nitrous control, lean protection, gear compensation, launch control, full throttle shift etc)
I have to start getting e-checks here in ohio next year and I was going to go with the IP stage one and tune it with the flashpro. So all they do is check for cel's on the obdII via the diagnostic port, so I should still be able to pass the e-check with this since it shouldn't be showing any cel's, is that correct?
D
