Flashpro
Old Nov 13, 2009 | 04:19 PM
  #41
Gernby's Avatar
Former Sponsor
I consider myself a "noob" at tuning as well, even though I spent over a thousand hours developing a custon, self-tuning, wideband piggy-back ECU that worked AWESOME on my '02 S2000. I later spent several hundred hours enhancing that piggy-back so that it would be CAN bus enabled for my '06 Lexus IS350.
The only thing that I can really pass on from that in regards to the FlashPro is that you are better safe than sorry! DO NOT start dicking around with ANYTHING without having a good idea of what the outcome will be!
Old Nov 13, 2009 | 04:23 PM
  #42
jdsaini's Avatar
[QUOTE=gernby,Nov 13 2009, 05:19 PM] I consider myself a "noob" at tuning as well, even though I spent over a thousand hours developing a custon, self-tuning, wideband piggy-back ECU that worked AWESOME on my '02 S2000.
Old Nov 13, 2009 | 11:43 PM
  #43
alSpeed2k's Avatar
Documenting your experiences will help us guys that plan to get it in the (near?) future! thanks!
Old Nov 14, 2009 | 04:58 AM
  #44
whitt1's Avatar
I used HPtuner software for a couple of years,with it you could add a aftermarket wideband o2 sensor and log the fuel and timing maps,then make he changes needed by laying the log screen over the engine map screens and key in changes.Is this the case with Flashpro?You could also add additional features in my case a 3bar map. With HPtuner you could also change injector and MAF calibrations,can Flashpro do this? Is there an automatic smoothing feature for the maps?
Old Nov 14, 2009 | 06:19 AM
  #45
Gernby's Avatar
Former Sponsor
You can download the FlashProManager software, and play around with a demo calibration.
Old Nov 15, 2009 | 12:47 PM
  #46
Swift GT's Avatar
Originally Posted by HighwayStar,Nov 12 2009, 08:09 PM
if i return the setting to stock will a honda dealer know that i played with the ECU?
This question wasn't really answered... can the Honda dealer see that the ECU has been played with (and thus void the warranty)?
Old Nov 16, 2009 | 08:18 PM
  #47
herrjr's Avatar
Originally Posted by Hondata,Nov 11 2009, 12:05 PM
There are no huge gains on a stock engine. The stock fuel is good (it is about right, but not that smooth) and the stock ignition settings are also good. Honda tuned this vehicle very well from the factory.
So what is else is necessary in order to make this useful? Is a TP and exhaust enough, or do I need headers, intake etc?
Old Nov 17, 2009 | 11:25 PM
  #48
brand0n's Avatar
So it would be better to use a normal wideband gauge vs the one flashpro comes with?
Does the AP2 primary o2 sensor read as good as the RSX?
Old Nov 19, 2009 | 01:33 PM
  #49
thesilverbullet's Avatar
gernby - did you get your a/f cleaned up and can you post your a/f graph w/ map?
Old Nov 19, 2009 | 01:49 PM
  #50
[QUOTE=herrjr,Nov 17 2009, 01:18 AM] So what is else is necessary in order to make this useful?
