Flashpro base map vs tune
Old Mar 10, 2011 | 08:02 PM
DG's Avatar
DG
Default Flashpro base map vs tune
I just installed the Flashpro software and found 2 base maps (toda & mugen) that seem to be fairly close to my bolt-ons. My question is, will one of these two maps be sufficient for me to have the car running right or should I have it e-tuned (e-tunez, evans, etc..) Will there be a noticeable difference between the two?
Bolt-ons are Berk HFC, Greddy SE and K&N
Thanks
Old Mar 10, 2011 | 09:39 PM
psychoazn's Avatar
A tune will net you more power. If you already have the flashpro and all the bolt-ons, then paying to the tune is just icing on the cake
Old Mar 11, 2011 | 05:47 AM
xredjar's Avatar
I had e-tunez tune mine and while I did not see huge gains on the dyno, there is a huge improvement in driveability and response. It's much better than a stock calibration after being tuned. One of the side benefits is that by tuning they can dial your STFT and LTFT in to just a couple percent which is much lower than stock. I'm very happy with the tune, and I'm not loosing any mileage either.....win / win!!
I've got a review in this forum....goes into more detail.
Old Mar 11, 2011 | 07:37 AM
scareyourpassenger's Avatar
Typically there is little power to be gained as mentioned earlier. The drivability is a big difference and depending on the tuner you may find another 15% more low end torque
Old Mar 12, 2011 | 09:31 AM
DG's Avatar
DG
Thanks for the replies. Do most have a preference between online etuners (e-tunez, evans, etc...)?
Old Mar 14, 2011 | 09:45 AM
xredjar's Avatar
I was the beta S2000 for Steve at e-tunez, and really love how the tune turned out. They are really easy to work with, & to get you the tune & feel you want.
Highly recommend them!!
I can't comment on other services since I haven't used them. I can only tell you e-tunez worked great for me!!
Old Mar 17, 2011 | 10:02 PM
ace123's Avatar
Thanks
i've got very similar mods--berk 70mm hfc, q300 and fujita intake. i'll probably not get a tune until i add a header. i'm starting with the canned tunes and cleaning up the afr, and i like the mugen one better than the toda for my mods. gernby posted a great spreadsheet that estimates road torque if you are either just curious or are comfortable working timing yourself. i can send it to you if you can't find it on the boards.
good luck if you do an etune--let us know how you like it! i'd love to see the maps to compare them, but i'm not sure whoever performs it would like that.
kryptonite
Jan 22, 2013 12:54 PM
s2kscott
Jan 7, 2013 12:54 PM
starchland
Sep 14, 2011 04:09 PM
scareyourpassenger
Mar 4, 2010 04:35 AM
