FlashPro HELP PLEASE
Old Dec 15, 2012 | 07:23 AM
JayC07's Avatar
Default FlashPro HELP PLEASE
I've been running "stock tuned" on my car for a while.. just put on a test pipe and tried to do the TODA calibration and now when i go to upload the tune to my flashpro I get an error saying "this flashpro can only be used with 2006-2009 Americas Vehicles" WTF!!!
Old Dec 15, 2012 | 07:35 AM
JayC07's Avatar
i am so pissed the fk off with this shit
Old Dec 15, 2012 | 07:46 AM
JayC07's Avatar
also it wont let me unlock it from the vehicle ...get another error saying "the ecu vin has not been recorded"... ALSO on the bottom left there is no check mark next to ECU..just a red X
Old Dec 15, 2012 | 08:03 AM
Gernby's Avatar
Former Sponsor
Have you rebooted your computer with the flashpro disconnected from the computer and car?
Old Dec 15, 2012 | 08:06 AM
Gernby's Avatar
Former Sponsor
Make sure to disconnect the flashpro from the car too, so it will be fully reset. If all else fails, you should reset the ECU by pulling the fuse or disconnecting the battery.
Old Dec 16, 2012 | 10:50 AM
JayC07's Avatar
The only way i can get it to work is if I load the tune thru my laptop. Ill have to reset my ecu then and start fresh im sure that will fix it
Old Dec 17, 2012 | 07:02 AM
Gernby's Avatar
Former Sponsor
I rarely ever try to flash a new calibration without using my laptop. I've had way too many close calls, where the flash would be corrupted, and I couldn't start the car. I would have to flash it again and again back and forth between calibration A and B before the car would finally start. Basically, just use your laptop ...
deathsled
Mar 8, 2007 06:12 PM
J33LUS
13
May 31, 2006 03:37 AM
BlueS2000Boy
Jul 31, 2004 09:55 AM
s2kwik09
May 30, 2004 07:44 PM
OneQuickS2K
Feb 27, 2004 04:23 PM
