FlashPro Ignition Maps?
Old Jun 19, 2010 | 04:44 AM
Dan1987's Avatar
Default FlashPro Ignition Maps?
Could anyone show me a screenshot of their ignition maps from flashpro?
I pretty much have my fueling sorted but the ignition map is all over the place. Could do with something to give me an idea of how to proceed.
Mines and F20c, so i know it will be slightly different to your F22's but itll give me an idea of where to go with it.
Cheers.
Dan
Old Jun 19, 2010 | 06:00 AM
b.r.i.a.n.'s Avatar
i would run what ever it is that's used on the base map. you're better off adjusting the ignition timing map on a dyno.
Old Jun 21, 2010 | 01:14 PM
s57_s2k's Avatar
this is from DBW F20C
Old Jun 21, 2010 | 02:37 PM
ace123's Avatar
Cheers.
Dan
Do you get to use any of the same basemaps as we F22C guys, or are you out of luck?
I think very few of us have done any significant ignition tuning without a dyno or reasonable torque measuring technique. Perhaps if you list your mods, someone with a similarly done F20C could show you a tuned one? Otherwise, the above is pretty sweet.
Old Jun 22, 2010 | 11:21 AM
Gernby's Avatar
Former Sponsor
I suggest leaving the part throttle timing alone, and just focus on full throttle for peak torque without any knock counts. I have started a couple threads here about how I set mine.
Old Jun 23, 2010 | 01:54 PM
Dan1987's Avatar
Cheers. I know that really you need a dyno etc for proper ignition mapping but ideally do the same principles apply to ignition as fueling? E.g nice smooth maps with no crossing load lines/values? My fueling is at a quite nice 13:1 going to around 12.9:1 at the top end. Now im wanting to move onto the timing. My induvidual cylinder ignition trims are quite nicely balanced. Could i start by just using the standard ignition maps but just slowly advance the timing on the entire maps whilst monitoring knock and adjusting accordingly? Also how many degree's from standard are your ignition maps advanced by gernby?
Thanks
Old Jun 23, 2010 | 02:04 PM
Gernby's Avatar
Former Sponsor
You'd really need to just look at the threads I've started about ignition timing, otherwise I'll be typing for an hour.
afzan
Jul 9, 2014 10:48 AM
purekoryo
Dec 30, 2010 04:22 PM
Dan1987
Jun 20, 2010 11:54 AM
whiteflash
Apr 5, 2010 12:22 PM
wing
Aug 30, 2005 04:01 PM
