FlashPro review thread
Old Nov 14, 2009 | 08:28 PM
Excalibur's Avatar
I'm a newb, but flashpro is only available for 06+ correct? Nothing available for 04-05's?
Old Nov 14, 2009 | 08:31 PM
Gernby's Avatar
Former Sponsor
Only the '06+ ECU's are flashable. Owners of '99-05 models should just buy newer S2000's.
Old Nov 14, 2009 | 10:00 PM
nj1266's Avatar
Hey gernby, do you have a WOT log in 3rd or 4th gear with timing, AFR, and load logged? Can you post it? What was the AFR like stock and how did it change after the flash?
Old Nov 15, 2009 | 05:36 AM
Gernby's Avatar
Former Sponsor
I didn't log anything when it was stock. I do have logs for 3rd and 4th gear WOT pulls, but I'm not sure if I can post them in a format that you can read.
Old Nov 15, 2009 | 11:34 AM
nj1266's Avatar
Can you post a breakdown of the AFR and timing by 500 rpm increments?
Old Nov 23, 2009 | 11:54 AM
macr88's Avatar
So far I'm very happy with the flashpro and have been waiting quite some time for it (since 06).
I tried the base map first just to see if there was any change, it did feel a bit different but I'm not sure if that was just due to the ecu being reset. I'm still trying to get a grasp of the whole thing so as of now I'm just running the tuned map with vtec, rev limit and the secondary O2 edited.
Thank you Hondata
Old Nov 23, 2009 | 12:04 PM
Havana Joe's Avatar
Flashpro is the best thing since sliced bread, i love mine.
Old Nov 25, 2009 | 08:34 AM
crazysupratt's Avatar
what happens if you want to sell the flashpro?? can it be unlock and lock onto another car? or is it lock once and that is it so you will have to sell ecu and flashpro together.
Old Nov 25, 2009 | 09:12 AM
macr88's Avatar
You have to unlock it from your car by loading the factory map on your ecu.
Check out Hondata FAQ about the FlashPro, they've covered this question and I'm sure any others you might have.
http://www.hondata.com/flashpro_s2000.html
Old Nov 25, 2009 | 09:51 AM
thanks, should have gone there and read before posted, guess I was lazy, haha.
