flashpro wideband input
Old Jun 12, 2010 | 02:08 AM
s57_s2k's Avatar
Default flashpro wideband input
hi
I want to install NGK wideband but I dont know where E1 pin (ECT2 - Coolant temperature sensor #2) is located ? . and where should I ground the negative wire for data logging ? .
As for the primary wires (+ve and -ve) I use external (60 A) car battery .
in stock Euro S2000 calibration ECT2 is disabled !!! I dont know why
Old Jun 14, 2010 | 05:37 AM
Gernby's Avatar
Former Sponsor
I can't answer your question, but I'm curious to know which wideband controller you will be using.
Old Jun 15, 2010 | 03:19 AM
s57_s2k's Avatar
NGK AFX with bosch sensor , but I am going to upgrade to NTK sensor .
I think I should get service manual and Electrical Troubleshooting Manual .
Old Jun 15, 2010 | 06:33 AM
Gernby's Avatar
Former Sponsor
I'm not familiar with that unit, but it will probably work. I agree that you should definitely get the service manual, but I doubt you'll get any use out of the Electrical Troubleshooting Manual. The ECU pinouts and wiring diagrams are already in the service manual.
aphex4000
Apr 22, 2016 07:51 AM
thesilverbullet
Jul 21, 2015 02:52 PM
Siccished
Oct 29, 2010 08:12 PM
04S2kSS
Aug 20, 2010 06:27 PM
Travis Beste
Sep 26, 2002 06:35 PM
