Cam and Crank sensor info
Old Sep 26, 2002 | 05:56 PM
Travis Beste's Avatar
Default Cam and Crank sensor info
Hi all- I'm searching for some info on the cam and crank sensors. I need as much info as possible. If anyone has a factory service manual and could get me the info that would be great!!!
Travis Beste
Old Sep 26, 2002 | 06:09 PM
Chazmo's Avatar
Travis, OK... What exactly are you lookin' for. I've got the manual and a cold right here....
Old Sep 26, 2002 | 06:16 PM
Anything and everything you can tell me about them
I need to know how the PCM(don't know what term you "honda" guys use, Powertrain Control Module is what us chrysler people get) determines when TDC is, how many teeth/notches does the crank wheel have, when a notch passes does the signal go high or low- is .50V low??? is 5V high?
Like I said- anything you can tell me about it is more than I know right now.
Thanks AGain
Old Sep 26, 2002 | 06:23 PM
Chazmo's Avatar
Travis,
I've located the actual tolerance specs for the camshaft and valves (pg. 2-3 of the manual). I've also located a diagnostic description of the Crank Position Sensor (CKP) (pg. 11-73) and the Throttle Position Sensor (TP) (pg. 11-50).
What I can't find are actual specs for the sensors themselves. So, I'm not sure I can help you.
The PCM is known as the "PGM-FI" system on the S2000.
Old Sep 26, 2002 | 06:29 PM
OK, I guess I'll keep digging for the info. Also- anyone have a wire harness they want to get rid of cheap??? I am in need of either a whole harness or 3 of the 4 AMP connectors. They seem to be pretty tough to find.
O well- first race of next year is still many months away.
Thanks Again
Travis Beste
Old Sep 26, 2002 | 06:35 PM
Chazmo's Avatar
Best wishes, Travis. Sounds like you've got some fun nights ahead!!!
FYI, the shop manual is available from dealers for about $80. There's also a manual available (they call it a Helms manual) from some of the site sponsors, I believe. Surf around a bit. It sounds like you're gonna need one.
Good luck!
Kitesurfer s2000
Feb 1, 2011 12:20 PM
S2000BMW
Oct 26, 2009 08:43 AM
Eric220
Jul 17, 2008 10:19 AM
Toad17
Jan 28, 2007 10:27 AM
MrCaBBiT
Feb 9, 2005 02:36 PM
