Found the perfect EVAP code avoidance solution!
I have posted EVAP code avoidance questions several times, and although several kind people tried gallantly to help me, no one seemed to have an answer to how the EVAP CEL codes could be avoided for a situation such as mine in which one is using the original AP1 ECU in a vehicle that does not have a fully functional S2K EVAP system. The topic is apparently quite complicated because the Honda EVAP enhanced monitoring algorithm is very complex and very difficult to fool. I am happy to be able to tell all those who may be interested in an EVAP CEL avoidance strategy that Izze-Engineering has developed an EVAP Simulator kit for 2000-2005 US and Canadian market cars. The kit includes a clever circuit board that spoofs the ECU into believing it is monitoring a fully functional EVAP system. I have an AP1 engine transplanted into a 1966 MGB. The engine is managed by the original ECU. I had previously found solutions for all the missing sensor inputs (immobilizer, secondary O2, air injection system, and electrical load detection) but I was flummoxed by the EVAP code avoidance issue. The Izze-Engineering EVAP simulator solves the problem and allows me to have a fully functional MIL lamp (that is not perpetually illuminated) and normal OBD II diagnostics that are not littered with extraneous EVAP codes. I am betting that there are some other S2K guys out there who will likewise be very happy that this solution is now offered. You can read about the EVAP simulator on the Izze-Engineering website. Caleb Holloway is obviously a genius!
Morrisguy
Morrisguy
To the maker of the device: be very careful. The devices have no purpose other than defeating an emission control device, and if the EPA devices to investigate under the clear air act, things will not be fun for you.
Reference Casper Electronics
http://www2.epa.gov/enforcement/casp...-clean-air-act
http://www2.epa.gov/sites/production.../casper-cd.pdf
There are still places that only require a tail sniffer to validate if they are breaking any emissions or not (this is the real way to do it)
I have your air pump deletion and Izzy is a great asset to the s2000 community.
If/when I drop a f20/22 into a caterham, I'll probably be using this
The only emissions control applied to the 1966 was Positive Crankcase Ventilation. I have that requirement well covered.
Thanks,
Morrisguy
c32b
Mar 16, 2012 09:25 AM
