gettin a kpro...now what?
Originally Posted by DFWs2k,Feb 2 2010, 08:30 AM
are you speaking from experience? i know you can use the map as it is programmed on the unit, but i'm not seeing anything that says you can pull the map off
Originally Posted by 02s2knick,Feb 2 2010, 07:45 PM
yeah its from experience. i still own a 02 rsx type s with kpro which will be laying around once the car is sold. but its wise jus to have your map saved on your lap top (calibration as kamanger calls it...or cal for short) than to pull the cal off kpro. me personally didnt have very good luck pulling a cal off kpro due to the cal that was on there was loaded with a older version of kmanager that i didnt have.
you can download an kal from an ecu and save to your PC's hard drive and share with folks.
however, files can be locked via password so that you can not pull off an ecu.
you can download kmanager for free and view various kal files to see how the software works...
in the bar on the top of kmanager click online>tools>and download.
and you can "protect" the ecu but as kmanager say in the contents it just locks the map from being downloaded back and it cant be read or a new cal cant be uploaded. until you erase the ecu.
im thinking about putting kpro in my s2k since i already have kpro for the rsx but im jus worried about cruise control. i know they disable it for the tsx but they dont say anything about it on hondata so im going to assume that it still works
