Having start up issues on my ap1
Old Aug 19, 2012 | 09:59 AM
AWWHITE s2k's Avatar
Default Having start up issues on my ap1
So I installed the AEM V2 Standalone Ems about a week ago and got it tuned.. Now my car turns over 3-4 times befor firing up. And some times it just turns over and no fire up what so ever. My 1 s2k buddie said my Crank Postion Sensor could be going bad... And idea's what it could be... Befor I had aem v2 and car tuned/dyno car would run/ start up fine...any help would help me out... Bc I'm trouble shooting. Thanks for reading
Old Aug 20, 2012 | 08:55 PM
RedSunS2K's Avatar
I read that turning the car key all the way (like 3-5 seconds?) and let the fuel pump prime then press the start button helps.
Old Aug 20, 2012 | 09:17 PM
s2krider88's Avatar
agreed with above, while i was running the series 2 and everyone i know with ap1's running series 1s have the same issue it takes a few seconds to crank over.
Old Aug 22, 2012 | 07:13 AM
jh4db536's Avatar
http://static.photobucket.com/player...822_063530.mp4
Here is my cold start with a ems series 2. Took video this morning at 645am...car sat overnight. it will never be as good as stock, but it's all in the tune.
Sent from my T-Mobile G2 using Tapatalk 2
Old Aug 22, 2012 | 08:35 AM
tx2K's Avatar
Thats one of the best starts with AEM Ive seen since Ive been looking. Who tuned yours?
Old Aug 22, 2012 | 09:00 AM
jh4db536's Avatar
[media]http://www.youtube.com/embed/mTsozIkHW4U[/media]
I tuned it myself. That's the best way to deal with cold start. There's no science to it, pretty much trial and error and u get 1 or 2 chances per day.
The logs are only good for objectively measuring if the settings positively or negatively impacted starting performance. Because you need to know the time from stat sync to stat cranking off and the starting coolant temp for comparison.
Old Aug 26, 2012 | 12:31 PM
sohc_mshue's Avatar
Sounds like the tune. Try adding more cranking fuel.
Old Aug 27, 2012 | 07:53 AM
jh4db536's Avatar
10,000us cranking fuel is approximately the sweet spot for a ap2 with stock injectors and fuel pressure. Around 6k is default...
elyteNAs2000
Dec 1, 2014 06:23 PM
AWWHITE s2k
Nov 3, 2012 03:45 PM
AWWHITE s2k
Aug 20, 2012 02:05 PM
larenzo_cuhh
Mar 11, 2012 07:45 AM
vietdragontekx
Dec 7, 2010 10:11 PM
