High Idle
Old Sep 19, 2010 | 10:07 AM
jb34304's Avatar
Default High Idle
My car is idling above 1750 rpm's at all times even if the car is warmed up and I am cruising on the offramp in neutral Is this a tuning issue or a problem with the car?
Here is my calibration to look at:
Calibration 1.19
Old Oct 6, 2010 | 08:36 AM
maluch's Avatar
it's a tuning issue.... i highly suggest you find someone who knows what they are doing
Old Oct 6, 2010 | 11:45 AM
ZeroF's Avatar
Mine does the same thing, except when I come to a stop the Rpm's come down to normal range.
Old Oct 6, 2010 | 01:37 PM
Boofster's Avatar
It's hard for larger injectors to idle stock. I'm guessing you guys are using R/C's. Injector Dyanmics seem to behave better.
Also could be a sticky or dirty IACV, map sensor, vacuum leak.
There is an idle control correction option in KManager. Maybe mess with that?
Old Oct 6, 2010 | 10:36 PM
H22toF20's Avatar
Most likely a tuning issue.
Old Oct 9, 2010 | 08:48 AM
jb34304's Avatar
[QUOTE=Boofster,Oct 6 2010, 01:37 PM] It's hard for larger injectors to idle stock.
cmn
May 25, 2015 07:48 AM
timg
Sep 6, 2013 07:11 PM
Spoolin
Dec 12, 2011 10:52 AM
vietdragontekx
Jan 10, 2011 11:12 PM
