Hondata Flash Pro what to expect from Stock or HFC + Catback
Hi,
I'm getting installed my new HFC from berk Technology with my Toda Exhaust this saturday.
My car is a 2008 AP2 with a 2.0 litter engine (European Specs)
I have the possibliity to go for a hondataflash pro as well as a tuning.
My question is do i have to expect some significant gains or nothin until i am getting a header as well?
Thanks a lot
Thanks a lot
Probably not a huge increase in peak power/torque, but you should see significant gains in the mid range due to lowered VTEC engagement. From dyno plots I have seen, most headers don't make much if any additional power.
You can get very significant gains from a FlashPro tune if you replace the OEM cat with an HFC, test pipe, or one of my Gern-Pipes (in order of lowest to greatest gains). Gains from a header are difficult to achieve, even with a tune.
For such a mild build, you really should just get an eTune, which is $99 through my service with free touch-ups.
I just installed a Berk HFc with the toda catback the throttle response is already amazing and much better.
Acceleration is smoother too.
I will go with the toda header tooin a near future and try a hondata.
I'm not familiar with etune?
[media]http://www.youtube.com/watch?v=atLJAauc5CQ[/media]
An eTune is one that is performed via email. Basically, I would send you instructions for you to use your FlashPro to datalog a set of things, then email the datalogs to me, then I would make send you some different instructions, repeat, repeat 2-3 times, then you have a completely customized tune (full and part throttle) with optimized VTEC engagement window.
i too have an 08 s2000 with an intake and a test pipe, thats it! and with Gernby's tune it is night and day difference!! best mod you can ever do is get a flashpro!! best tuner on this site for the flashpro hands down
So I'm reading this and I'm wondering... So....
History:
'08 CR
Mugen header - Berk 63mm HFC - HKS exhaust
Ran fine.. no problems...
Update exhaust to Mugen
So, Mugen Header - Berk 63mm HFC - Mugen exhaust
CEL.. O2 sensor.
After failing emissions multiple times, I go back to OEM cat and bam.. bye bye CEL.. hasn't come back since.
I'm contemplating the Berk test pipe but not sure... 63mm? 70mm? Pros Cons to one versus the other?
Also, with Flashpro, IF, the check engine light comes back, can I clear just that specific code or is that not possible.... I'm also aware that come emissions time, I'll probably have to put the stock catalytic converter back on the car again.
History:
'08 CR
CEL.. O2 sensor.
With all those parts and the concern you have of being able to pass emissions. You would be better off selling all those and buying one of gerbys mid pipes. It has a catalytic converter and You will net more power than you would with all those other bolt ons
Boom two birds one stone
