hondata flashpro
Old Dec 18, 2009 | 10:30 PM
amusepanda's Avatar
Default hondata flashpro
will the hondata flashpro for the s2000 eliminate any check engine light?
-in my case i have an airpump problem. will this permantly erase the cel so i can get it inspected?
-will it erase ANY code (permantly)
yes i can get an airpump or the delete kit but, i plan on doing alot more engine work so i want the hondata flash pro.
-what else can i do to delete the cel for the air pump? is there any other electronic systems or other ways to do this other than getting an airpump or the delete kit.
thanks
Old Dec 18, 2009 | 10:39 PM
amusepanda's Avatar
well nvm its only 06 and up...ugh...is there any other electronic systems i could get
Old Dec 18, 2009 | 10:50 PM
Chow-bot's Avatar
most likely no,
i doubt anything will erase a code yet still let you pass inspections(depending whats inspected) i figure OBD II??
Old Dec 19, 2009 | 09:24 AM
TJ01s's Avatar
the only viable thing i know of that allows engine tuning and pass smog is the hondata k-pro. lucky us, for a mere $2000 we too can have one
Old Dec 19, 2009 | 12:46 PM
Chow-bot's Avatar
yes, but it wont erase CEL's
Old Dec 19, 2009 | 02:32 PM
spectacle's Avatar
Kpro can erase CEL's. But the airpump is an emission control so even if you disable it, the car still won't pass smog
Old Dec 22, 2009 | 10:33 AM
Gernby's Avatar
Former Sponsor
The air pump is just for cold starts, so it would not matter for a regular emissions test.
Old Dec 24, 2009 | 04:44 AM
spectacle's Avatar
I agree. With Kpro my car doesn't even look for it. Never done an emission test so I don't know how that works...do they start the test with the car cold or just when you show up?
morrisguy
May 16, 2019 05:05 PM
Manc_btcc
Oct 29, 2013 11:32 AM
stafaa
Dec 23, 2012 04:54 PM
batguano
Jan 25, 2008 02:23 PM
