Air Pump
Old Oct 28, 2013 | 01:03 PM
Manc_btcc's Avatar
Default Air Pump
Hi all,
Bought an S2000 recently and the owner informed me that the engine management is due to the air pump.
What easier buying a new airpump or getting a delete kit?
If delete kit which one is the simplest to install.
I've done a search and couldn't find an answer.
Furthermore the air pump may have physical been damaged previously as the car has a knock does this affect a delete kit from effectively working?
Many thanks
Old Oct 28, 2013 | 01:30 PM
GaryB's Avatar
You bought an S with a CEL light on?
What is the code it's giving you and have you read it yourself or are you going off what the previous owner is telling you?
Old Oct 28, 2013 | 01:41 PM
Manc_btcc's Avatar
Hi,
thanks for the reply
yes i'll get the code, the previous owner gave me a read out which pointed to the airpump.
dont worry im not that green lol.
i'll get a read out tomorrow, ive got an obd code reader.
Old Oct 28, 2013 | 01:49 PM
WinFreak's Avatar
Delete kit will replace the pump with a resistor, have a look in the for sale section for the kit I'm selling
Old Oct 28, 2013 | 02:32 PM
Vtechead's Avatar
The car has a knock ?That doesnt sound good are you sure its coming from the airpump ?
Old Oct 29, 2013 | 12:49 AM
GaryB's Avatar
I think the car has had a bump rather than it's making a knocking noise.
Old Oct 29, 2013 | 01:11 AM
s2konroids's Avatar
P1411 along those lines points to air pump.
Cheers
Old Oct 29, 2013 | 03:25 AM
Manc_btcc's Avatar
indeed the car has a bump in the past, ive bought air pump and a relay, which i should get delivered by the weekend i'll update the thread with an outcome.
Old Oct 29, 2013 | 04:03 AM
BenRNBP's Avatar
P1411 most likely indicates a stuck relay, though tbh it can also indicate that the air pump isn't plugged into the relay OR the air pump is stuck/seized and drawing too much current.
P0410 is the more general "there's something wrong with the SAI system" which could just be a disconnected pipe
TBH I'd ditch the lot and get one of WinFreak's delete kits - a much neater solution all round
Old Oct 29, 2013 | 11:32 AM
Manc_btcc's Avatar
thanks for all your help.
eparra83
Jun 16, 2019 10:35 AM
sZooo5
Sep 16, 2018 10:39 AM
Jake89
Oct 15, 2015 04:45 AM
BBV S2K
Jul 9, 2012 01:34 PM
s2k16803
Aug 3, 2009 09:47 AM
