Hondata Kpro III
Was just on Hondata's site and ran across the following:
http://hondata.com/kpro_v3.html
Looks like it's 250.00 for an upgrade.
Some of the improved features:
KPro III Enhancements
Twice the on board datalogging memory
Without additional analog inputs the KPro III has twice the datalogging length capability of the previous generation KPro. With analog inputs the datalogging length is approximately the same as the previous generation.
Three times the programming speed
The typical initial upload time has been reduced from over 30 seconds to under 10 seconds. Subsequent uploads are also faster.
8 additional analog inputs for datalogging.
The KPro board has eight 0-5V analog inputs, which can be used for temperature, pressure, wideband, EGT or any other input which provides a 0-5V signal. The analog values are both stored in the KPro and in any datalog made from the KPro, which means that you do not need to change the analog input settings which switching between datalogs from vehicles with different analog inputs.
Anti-theft security enhancements
Similar the the FlashPro, password protected owner information can be stored on the KPro. This results in a KPro which had owner identification which cannot be changed if stolen. Additionally, an upload security password can be used, which and renders the KPro unusable if stolen.
On board calibration storage
Similar to the FlashPro, the uploaded calibration is now stored on the KPro in a form which allows a quick and accurate download from the KPro.
Digital input
For future expansion, a digital serial input is present on the KPro.
Digital input
It would be very sweet if this would put a nail in the wideband usage- like using the STOCK RSX wideband with the seemingly simple protection and monitor that goes with it... in addition to things like fuel/oil pressure and oil temp...
