Hondata with what O2 sensors?
Old Jun 17, 2011 | 07:17 PM
*JG*'s Avatar
Default Hondata with what O2 sensors?
I will be running Kpro on my AP1 and I'm trying to figure out if I still have to run both of the stock O2 sensors? I will also be running a PLX wideband so hopefully the Kpro allows me to run only one stock sensor that way I only have to add one bung to the exhaust for the PLX. Any help is greatly appeciated
Old Jun 17, 2011 | 07:38 PM
DFWs2k's Avatar
yes you can only run one, you can even just run the plx wideband, and then use it to simulate a narrowband for the ECU, i believe
Old Jun 18, 2011 | 02:10 AM
*JG*'s Avatar
How do I link it up to the ecu as far as the ecu goes? The PLX has an output specifically for doing that but once i get to the ecu wiring, I'm lost. I would love to be able to just run one O2 because that would cut down on work that I have to do
UberDuper
Oct 17, 2015 03:41 PM
Croc
Apr 14, 2014 04:01 AM
ack5252
Oct 7, 2010 06:48 PM
DBXFX
Sep 30, 2010 08:30 AM
