Minimum Requirements for Stock ECU to function
Old Oct 7, 2010 | 04:06 PM
ack5252's Avatar
Default Minimum Requirements for Stock ECU to function
I am in the middle of stripping down and rebuilding the majority of my AP1 and have a question regarding how many auxiliary systems I can remove (secondary air system, a/c, etc.) before causing the stock ecu to not properly function. I could care less about CEL's as I'm looking to redo the motor with stand-alone ecu eventually but in the meantime I want to be able to run the stock engine and ecu combo. Is throwing CEL's the extent of removing these systems or will this actually cause the ecu to not properly function?
Thanks for the input!
Old Oct 7, 2010 | 05:43 PM
chris_barry's Avatar
I stripped back a wiring loom for my race car.
The ECU needs the key reader, wheel speed sensor, primary O2 sensor, power supply and PCM relays to function.
My race car is missing the air pump and associated relays.
I retained the main fuse box so also have the current load detection circuit.
Old Oct 7, 2010 | 06:48 PM
ack5252's Avatar
Perfect man that is exacty what i needed to know, thanks a lot!
UberDuper
Oct 17, 2015 03:41 PM
Chief Robert
May 26, 2012 05:26 AM
wotto1
Jul 6, 2007 05:32 AM
BlueS2000Boy
Jul 31, 2004 09:55 AM
dereks2000
Feb 20, 2003 06:54 PM
