id1000cc injectors install question
Old Mar 2, 2011 | 12:01 PM
azride1983's Avatar
Default id1000cc injectors install question
hey guys, i'm wondering if the installation is straight forward? will it fit directly? is it suppose to have some bushing/washer included on the kit? i only receive 4 injectors and the plug and play clips..thanks
Old Mar 2, 2011 | 12:40 PM
3en's Avatar
3en
If you have the plug and play clips it is a very easy install.
Remove the 2 black nuts on the black plastic cover
Remove the 3 nuts on the fuel rail
remove the 2 bolts on the FPR
pop up the fuel rail and remove injectors
install new injectors with a little bit of lube on the orings
Install is the reverse of removal.
Good luck
Old Mar 3, 2011 | 07:23 AM
Round 3's Avatar
You might need some washers too
Old Mar 8, 2011 | 09:10 AM
azride1983's Avatar
thanks.. already installed.. fit like the stock injectors. no washers required..
RedSunS2K
Oct 15, 2011 02:20 PM
batikan
Nov 5, 2010 04:49 PM
s2guru
Sep 28, 2007 07:43 AM
Phillie
Nov 25, 2006 10:42 PM
pushin9
Oct 22, 2006 09:19 PM
