Infinity 6 Lambda1 not found
Old Oct 18, 2015 | 08:39 PM
infamous_jrh's Avatar
Default Infinity 6 Lambda1 not found
Hey everyone, looking for some help here.
I have just installed AEM infinity 6 on MY02 S2000. I have uploaded the base tune and the car starts and runs. However, im not showing any lambda1 data. The tables show no data, and upon loading the basictuning layout an error reads lambda1 not found. I have an AEM 30-2001 wideband installed in the manifold witht AEM extention that plugs into the s2000 pnp harness and an uego gauge/ sensor installed in the test pipe. No factory o2 sensors are installed. I have verified voltage from the pnp and the ext to the wideband and all is good? Any ideas on why its not reading. I have tried 2 sensors with the same result.
Old Oct 19, 2015 | 06:39 AM
TheCarGuy2021's Avatar
You have a mismatched ECU firmware version and Infinity Tuner software version. If you're on v96.1 firmware, try downloading and installing the latest Infinity Tuner from the AEM website and try connecting again. Be sure to start from one of the v96.1 Infinity Tuner layouts as well.
Old Oct 19, 2015 | 07:20 AM
Ill try that when I get home from work. Thanks
I broke my old computer so this is a new one with newly installed infinity tuner. Ill try to update my computer or boot off of my old hard drive.
Old Oct 19, 2015 | 04:01 PM
Turns out you are right on the money! Thanks you!
-Jake
Old Oct 19, 2015 | 04:24 PM
V6 Donut's Avatar
-Jake
Woot! Thecarguy saves the day!
Old Oct 20, 2015 | 06:56 AM
-Jake
No problem!
In v96.1 some channel names were changed to include the unit currently being used to enable an easy global change of units (Ex. "Lambda1" changed to "Lambda1 [Lambda]" and can now be changed by the user to AFR gasoline, AFR ethanol, AFR methanol, etc.). The old v96 Infinity Tuner/Layouts were still looking for the old channel names that don't exist on the new v96.1 ECU firmware.
Bajabajabs
Apr 16, 2018 05:15 AM
unvmys2k
Apr 3, 2017 05:11 PM
pezee
Jul 6, 2015 09:20 PM
umair
Jun 17, 2015 05:42 AM
s2konroids
Jul 30, 2013 04:02 PM
