is it necessary to sync wideband to aem?
Old Jun 16, 2015 | 07:29 PM
umair's Avatar
Default is it necessary to sync wideband to aem?
Right now i have my wideband hooked up but not the the aem ems. Is it necessary to do so? I bought a full setup and the previous owner had it synched.
Thanks
Old Jun 16, 2015 | 08:45 PM
liquid_helix136's Avatar
Yea, IIRC, you just need to fiddle with the o2 gain setting until it's spot on with the gauge
Make sure the wideband is grounded to a solid ground otherwise the voltage reading to the ECU will fluctuate and give inaccuracies. Make sure you aren't running non-resistor spark plugs too, that messes with every signal in the damn car
Old Jun 17, 2015 | 12:12 AM
riceball777's Avatar
For tuning and loging yes. If your already tuned and don't plan to ever log or mess with the tune then no there is no point.
Old Jun 17, 2015 | 05:42 AM
yamahaSHO's Avatar
The WBO2 can be used for O2 feedback... As in, it can be in closed loop ALL THE TIME. I depinned my stock O2 wire at the ECU harness and pinned in my WBO2 feed. I didn't have to adjust anything to make it match the display of my WBO2 and I keep mine in closed loop all the time.
gfresh86
Jul 5, 2014 12:51 PM
s2konroids
Jul 30, 2013 04:02 PM
Competitor9
May 24, 2010 05:39 PM
NVD52K
Australia & New Zealand For Sale and Wanted
20
Jul 10, 2008 03:39 PM
AusS2000
Jul 7, 2005 04:38 PM
