Knock Control with Aem Ems
Old Jun 8, 2011 | 01:40 PM
bluemetals2k's Avatar
Default Knock Control with Aem Ems
Need to setup the knock control on my nitrous s2000 ( mods in sig ) anybody have any idea's? tricks? tips? bookmarks? or vast knowledge? lol
Tried the search function it failed AGAIN to find anything close.
Old Jun 9, 2011 | 06:00 AM
spectacle's Avatar
Doesn't the AEM software come with a help file?
Old Jun 9, 2011 | 07:37 AM
wadzii's Avatar
Banned
yep, read the aem pro instructions.. they explain it very well.
i would recomend NOT adding fuel, only removing timing. If you arent careful you'll melt a piston w/the knock control
Old Jun 11, 2011 | 09:11 PM
well we wouldn't want that!
Old Jun 11, 2011 | 10:34 PM
H22toF20's Avatar
Tuning 101 lol
I'm curious about this topic as well, sense I just ordered my V2 today.
Old Jun 13, 2011 | 08:58 PM
Originally Posted by RealStreet
I would set it up with the following steps.
1. Using the internal logging log the following, engine speed/engine load/O2/IAT/ECT/knock raw/knock volts/knock tooth/knock fuel and knock retard. It's important that you're logging the knock channels on the fast channels( with the rate on 250 samples per second). It's worth noting that trying to do this with PC logging isn't going to work. I set the loggers up to "loop log" so whenever the engine is under load it's logging. This way the next time I see the car I can go in and suck out all the logs from all the times the engine has been beat on.
2. Develop a baseline of "noise" the knock sensor makes NA. You're lucky enough to have most of the work done for you, the sensor is "tuned" to the frequency of "noise" the F20c/F22c makes so you don't have to do any of that setup. If your car is already boosted and you need a baseline you may use a higher octane fuel to base off of as tuning errors will be covered up with octane.
3. When you upload the log to analyze the data you are going to compare your baseline knock volts to your boosted/nitrous knock volts. If you have a spike in knock volts that wasn't present in your baseline you can consider this to be a problem.
The parameters that your logging are pretty self defined. If you're working with a engine that has poor distribution and one/two cylinders are showing more issue than others this If the knock retard shows events that require more than 3-4 degrees to get under control it's safe to say your tune is too hot. You will be watching "knock tooth" to tie knock events to it's corresponding cylinder. If this is the case you can use the individual timing trims to remove lead from troubled holes.
This is all assuming you have a decent handle on your fuel curve and you're not making big changes in your timing map. I guess in short, the knock control is a great feature it just requires time to set and and tune.
If you have any specific questions I'll do my best to answer them.
don't you have to wire up the knock sensor to an input channel on the aem ems? or am I getting the wrong info?
Old Jun 14, 2011 | 11:07 AM
H22toF20's Avatar
Wait. So if I'm N/A I don't have to change anything?
Old Jun 14, 2011 | 11:26 AM
wadzii's Avatar
Banned
You always need to establish a baseline knock noise for you particular engine..
Old Jun 14, 2011 | 11:46 PM
H22toF20's Avatar
What if I plan on street tuning it myself? I'll probably dyno tune it myself, but that'll be way later down the road. Just log the stuff you listed and make an educated decision?
S2K-NL
Jan 3, 2016 04:41 AM
pistolas s2000
Ηλεκτρικά Θέματα
Feb 15, 2014 12:16 AM
LTB
Jun 28, 2010 10:05 AM
inneedindeed
May 22, 2009 08:42 PM
slizzle
Mar 6, 2009 11:08 PM
