Knock control flashpro
Old Jul 1, 2010 | 09:38 AM
azunboy's Avatar
Default Knock control flashpro
I was messing around with the flash pro for my buddies car and I noticed his car is retarding timing around 20 degrees in the midrange RPM causing a hesitating sputter.
Then I tried to disable his knock sensor in the calibration tab.
Went for a part throttle pull and its still pulling timing like crazy.
His car is boosted with a greddy kit at 7lbs, but what else is causing the car to pull timing like that even with the knock sensor disabled??
Old Jul 1, 2010 | 09:46 AM
Gernby's Avatar
Former Sponsor
I resolved all my knock retard issues by adjusting the knock sensitivity tables. I think that would be way better than disabling the knock sensor. You can do a quick test by just doing a -10% adjustment on the whole table.
Old Jul 1, 2010 | 10:18 AM
azunboy's Avatar
That I understand, just trying to figure out what else causes knock retard other than the knock sensor
Old Jul 2, 2010 | 06:50 AM
Gernby's Avatar
Former Sponsor
I don't think anything else causes "knock retard", but there are several things that cause retard (IAT, ECT, MAP).
joefish1298
Jul 20, 2012 05:57 PM
azunboy
Jul 19, 2010 09:25 AM
Kirpich
Sep 5, 2008 11:27 PM
BigpoppaHurtm
Jul 18, 2006 10:32 PM
