Kpro 3 and battery tender
Old Nov 7, 2015 | 12:13 PM
Wateke's Avatar
Default Kpro 3 and battery tender
I don't know if discussed before, but I can't find the search option.
I'm about to install the noco genious g1100 wires to my battery and leave the tender running during winter. I'm running Kpro 3 on 01 AP1 no electronic mods, Can I attach the tender without damaging the ECU? Or do I have to remove the battery cables and then keep the tender on the battery by itself?
Old Nov 7, 2015 | 12:52 PM
Chuck S's Avatar
This will cause the the same damage your alternator/rectifier cause if you don't disconnect the battery...
-- Chuck
Old Nov 7, 2015 | 01:12 PM
Wateke's Avatar
True. I was more worried about the difference on how the alternator charges vs the tender (4 step charging, battery diagnostic, etc). I know the amp output rating from the tender its way below the alternator output. I just wanted some experiances before I mess something up. I knew it was probably ok, but its better safe than sorry.. Thanks for the reply Chuck.
ralper
Jan 18, 2017 07:47 AM
jpembry
Dec 30, 2011 06:33 AM
kimimila
Jul 13, 2011 09:02 AM
philipf22
Mar 2, 2006 03:47 PM
