Kpro Question: Map change on the fly
Old Mar 30, 2010 | 08:47 AM
S20004ME_PDX's Avatar
Default Kpro Question: Map change on the fly
I tried some search, but no luck so far so I thought I make a post. Apologies in advance if someone already posted this question.
Can Kpro change maps on the fly? i.e. If I go the route of Water/Meth, and if the water/meth system fails for whatever reason, and it has all the proper fail safes, is there a way for the system to notify Kpro, and have Kpro be switch to a none water/meth tuned map?
I'm also running an exhaust cutout, and was wonder if I could switch map on the fly between a open and closed cutout tune.
Thanks!
Old Mar 30, 2010 | 06:39 PM
96-EJ6's Avatar
The K-Pro does not have the capibility to switch from primary to secondary tables. However, the nitrous control output can be setup based on several paramaters. So for example when your on water meth the nitrous control is able to modify fueling and ignition timing only when water/meth is being injected. Settings can be based on engine speed, engine load, throttle angle, vehicle speed and knock count all having to fall within a window you specify. It works very well. I would actually recommend using the K-Pro to control the water/meth injection by itself via the nitrous control. Just download the software form Hondata and play with it to get an idea of what it can do.
Old Mar 31, 2010 | 06:18 AM
Thank you~
Even though I didn't get as many responses as I had hoped, but this was a great answer.
Old Apr 1, 2010 | 06:08 PM
JustinC's Avatar
Yeah, that is the way to do it. You can also use different sensors and relays in order to control the arming input through the ecu
Old Apr 6, 2010 | 06:58 AM
I think I will go this route. Does anyone have any recommendation in terms of the brand the water/meth system that would work best with Kpro?? I've been doing a lot of reading, but without real world experience, I really can't tell which system will work best.
911GT2
Feb 24, 2010 10:12 PM
911GT2
Forced Induction For Sale
Feb 19, 2010 11:59 PM
folex187
Oct 4, 2005 10:10 PM
billy_i_vtec
Nov 16, 2004 12:52 AM
Clayman
Mar 17, 2004 01:38 PM
