lowering redline in kpro
as long as it's higher than ap2 guys, i'm good, lol, i'm still on ap1 retainers, and they just switched our gas to include 10% ethanol, and i knock a little bit at high rpms, so i'm multi-paranoid
Originally Posted by deathsled,Jun 7 2010, 10:52 PM
or you should just not rev that high and not change anything aside from when you shift?
It's pretty easy to NOT rev to 9400....
After thinking about it, maybe it would be a good idea to lower the rev limit even more, at least until you have everything dialed in, and you're used to the extra power.
I don't know if the KPro has this issue, but I've noticed that the stock ECU doesn't cut fuel exactly at the rev limit, and does overshoot the rev limit by a couple hundred RPMs at times. For example, I have my rev limit set to 8500 RPMs, but when I hit redline in 3rd gear, the RPMs will reach as high as 8700. I believe this is due to latency in RPM calculation. I suspect that it would overshoot even more in 1st gear due to the increase in accelleration rates. I also think it would overshoot even more still if I had a turbo, and much, much more if my tires were to break loose in 1st gear.
