lowering redline in kpro
Old Jun 4, 2010 | 07:51 AM
DFWs2k's Avatar
Default lowering redline in kpro
I have kpro and it is tuned and has a redline of 9400, can I just input 9200? that wont affect anything else, will it?
Old Jun 4, 2010 | 08:17 AM
camuman's Avatar
should be fine. i thought all you ap1 guys loved revvin the piss outa the motor
i keed i keed.
Old Jun 4, 2010 | 10:22 AM
DFWs2k's Avatar
as long as it's higher than ap2 guys, i'm good, lol, i'm still on ap1 retainers, and they just switched our gas to include 10% ethanol, and i knock a little bit at high rpms, so i'm multi-paranoid
Old Jun 4, 2010 | 02:25 PM
JustinC's Avatar
yeah, no problem by lowering the redline
Old Jun 4, 2010 | 04:15 PM
DFWs2k's Avatar
does doing that make sense? i just don't want to have to have another engine put in by being uncautious
Old Jun 7, 2010 | 07:48 AM
Gernby's Avatar
Former Sponsor
Makes sense to me, especially since you're boosted. I don't think the high RPMs are as beneficial to you as they are for us NA guys.
Old Jun 7, 2010 | 07:52 PM
deathsled's Avatar
or you should just not rev that high and not change anything aside from when you shift?
It's pretty easy to NOT rev to 9400....
Old Jun 8, 2010 | 02:04 AM
DFWs2k's Avatar
hm really?
i guess it's safer to guess what RPM I'm at over 9000 than to utilize a feature of a system that is already installed?
Old Jun 8, 2010 | 05:55 AM
Gernby's Avatar
Former Sponsor
That's pretty stupid. If you want to rev to only 9200 for safety's sake, then you should set the rev limitter at 9200. The tackometer only goes up to 8900 or 9000, IIRC, so the difference between 9200 and 9400 would be pretty difficult to guess.
Old Jun 8, 2010 | 06:05 AM
Gernby's Avatar
Former Sponsor
After thinking about it, maybe it would be a good idea to lower the rev limit even more, at least until you have everything dialed in, and you're used to the extra power.
I don't know if the KPro has this issue, but I've noticed that the stock ECU doesn't cut fuel exactly at the rev limit, and does overshoot the rev limit by a couple hundred RPMs at times. For example, I have my rev limit set to 8500 RPMs, but when I hit redline in 3rd gear, the RPMs will reach as high as 8700. I believe this is due to latency in RPM calculation. I suspect that it would overshoot even more in 1st gear due to the increase in accelleration rates. I also think it would overshoot even more still if I had a turbo, and much, much more if my tires were to break loose in 1st gear.
