lowering redline in kpro
Old Jun 8, 2010 | 08:46 AM
DFWs2k's Avatar
hm,my tires don't break loose, and yea you are right, there is some lag, I've had peak RPMs of 9450, and I don't think that I had hit a rev limiter then, but honestly idk
I need to hurry up and have retainers replaced so that I will feel more comfortable, I'm comfortable w it being 9200 and occasionally seeing 9300
Old Jun 8, 2010 | 09:37 AM
camuman's Avatar
set it at 9200rpm, then get the shift beeper from modifry, and have it do the final beep at 9k. honestly, your not gonna notice that 400rpm loss.
Old Jun 10, 2010 | 09:20 PM
DFWs2k's Avatar
finally got it set, now I need to find out if there's a way I can set the car to shut off after X minutes when letting people drive it
Old Jun 11, 2010 | 05:09 AM
chef-j's Avatar
^lol why you need that? Damm I need to make a time to go to meet, so I can check out your setup.
Old Jun 12, 2010 | 10:33 AM
DFWs2k's Avatar
yea you do , i try to go to all of them or meet up with some of the people afterwards
Old Jun 15, 2010 | 10:43 AM
DFWs2k's Avatar
just wanted to add some more info
so my redline is now set at 9200 rpms, while i was accelerating the other day, i hit 9410 rpms, but there was no knock count, i think it has something to do with fuel cutoff vs the other type of cutoff?
this was in 1st gear and the wheels were spinning, so maybe no load, too? idk, just stating additional information
Old Jun 15, 2010 | 11:07 AM
Gernby's Avatar
Former Sponsor
I'm glad it only went 200 RPMs past your limit. I would have expected more than that with the wheels spinning in 1st gear. I am almost certain that the reason why it can't hit the exact target RPM is due to latency in the RPM calculation. The ECU has ti time how much time there is between each pulse in the RPM wire, and average those samples with previous samples. By the time the averaged / calculated RPM value hits 9200 RPMs, the actual crank speed is well past 9200 RPMs.
Old Jun 15, 2010 | 11:20 AM
DFWs2k's Avatar
makes sense, i wonder if it's different for each gear too, because before, the few times when i would hit the rev limiter, it would be in 3rd or 4th, so revs weren't increasing as fast as they would in 1st, so the highest rpm i saw with a 9400 rev limit was still under 9500
badboy00z
Nov 27, 2021 01:29 AM
ssjhook
Oct 8, 2017 08:08 PM
hypforlife32
Jul 27, 2010 06:01 AM
13darkknight
Dec 1, 2007 10:26 AM
147mphAllDay
Jan 11, 2006 01:54 PM
