Mr/Ms. Hondata....really
Originally Posted by ans2k' timestamp='1329110632' post='21408671
with all my mods and flashpro, the bottom rpms still felt sluggish. and didnt really do the trick. gears solved that for me. i th
that would drive me crazy..invest all the time and cash and hassle
only to have her lackluster until you reach 4K.
gernby..all due respect..I love reading all your research/experiments/
and dyno readouts but you and I have drastically different goals
for our Hondas!
I'm not worried about having more speed in a certain gear...or
being beaten in a "rolling-start" drag race@25mph!! wtheck?
I'm happy with just a bit more punch..a bit more gear-response..
if someone if some piece of crap(which everything next to me is!)
happens to nose ahead of me on International Speedway Bvld. so
be it..if there was $100K on the line my attitude would be different lol
You're into max results/performance...2 letters for you..FI!
uke:
If anyone is expecting and kind of "low end" out of this car, you bought the wrong car, simple as that. Adding some gears to make it a little more peppy off the line is like pissing in the wind if you ask me. If you want shorter gears, fine.. but "improving" the low end on a street car by shortening the gearing (on a car with already very short gears) doesn't make a whole lot of sense to me.
These debates about gears always end the same, and I always just give up. People just don't understand the mathematical certainty that there is nothing truly "gained" when changing final drive ratios. I just want the OP to understand that he should really spend some time analyzing his driving habits, usual crusing speeds, downshifting, and performance goals so he can calculate what specific gear ratio would give him the best experience. I believe Honda got it right with the AP1, then messed it up with the AP2 by shortening the gearing AND lowering the rev limiter. The AP1 can almost hit 66 MPH in 2nd gear, but the AP2 can only reach 58! Why would anyone want to restrict that down even further? That's without even mentioning how sucky it winds up being on the highway...
uke:
uke:also, it doesn't improve low end but it does make it feel easier to drive around town. it helps make up for the lack of torque this car has. just my 2 cents.
also, why the hell are we off topic? this is the wrong forum to be talking about gears. there is a whole thread else where for this crap. lol
just saying. low end is going to suck on this car. agree to disagree. but flashpro with help tremendously in the midrange, with is also lacking in this car. this car stock, was like step on the gas, nothing, nothing, nothing, nothing, BAMMMM VTEC!!!!!!! VTEC KICK IN YO!!! and when you only have 2000 rpms of power, it sucks. it just isn't enough.
If you compare max speed per gear and torque to the ground for a stock AP2 and an AP1 with 4.77's, they are almost identical (gears 1-4). Putting 4.44's in an AP2 would be about like putting 5.16's in an AP1.
Well..after all of this I truly agree with ans2k...sure..gears don't add
anything measurable..e.g. torque nm..horsepower nm..but let me borrow
from my biking backround...
with what power a person can produce...I know when I shift to a smaller
gear I'm gone until the gear runs out and I shift to a higher gear.
With limited power in this car..by gearing I think you are using what
the car is giving you to it's fullest....why was the Civic SI(1999)
giving a 4.40 FD? idf you remember it was a paltry 160HP..
Back to the purpose of this thread....if I just did the Flashpro with
no other changes(no TP..no CAI.no header..no exhaust)
would I gain any performance?
of course I'm thinking dyno tune to go with the Flashpro..but
nothing else.
Would it be worth the estimated $850?
nothing else.
Gearing is all personal preference. The JDM ITR had an even shorter FD, and it had more torque/power than the Si.. To each his own.
Just remember that gearing changes don't "add" performance. They just move it. When you go from a 4.10 ratio to 4.44, then you are simply giving up a LOT of performance between 34.5 - 37.8 MPH in order to have better performance from 0 to 34.5. You are also giving up a LOT of performance from 53.5 -57.9 in order to have slightly better performance betwwen 37.8 - 53.5. You are also giving up a LOT of performance 73.8 - 79.9 in order to have slightly better performance from 53.5 - 73.8. So if you do the math, the only way you can be sure that a 4.44 equiped car will "beat" a 4.10 equipped car is if you are drag racing from a stop. If you drag race from a 25 MPH roll, the stock geared car has a good chance of winning. So gear swaps should not be considered "performance adders" at all. They are just performance changers.
However, a few choice bolt-ons and a custom FlashPro tune definitely is a performance adder! There are no performance trade-offs, just better performance, especially where it's needed the most ... the midrange.
would it be safe to say that rolling between 0-34.5 the 4.44 has the advantage over the 4.1, same with rolling at 37.8 - 53.5? and same as rolling at 54.5 - 73.8?
if thats the case, what would be the speeds for a 4.77 advantage?
while were on the ems section... gernby what do you think about the kpro ap1 basemap?
Not safe to say at all! In fact, If you were to do a rolling start drag race from about 20 MPH, the small advantage that you would have from 20-34.5 would not compare to the huge advantage that the stock gear'ed S2000 would have from 34.5-37.8. Basically, you would slowly inch ahead a bit until you had to shift to 2nd, then as soon as you shift, the stock S2000 would shoot past you until he had to shift. You would start creeping forward again, but every time you had to shift, the stock geared S2000 would pass you again. The only time you know for sure that the lower geared S2000 would always win is if you get the full benefit of 1st gear (i.e. from a stop).
