Is my UEGO failing?
Old Sep 8, 2010 | 11:51 AM
MB's Avatar
MB
Member
Default Is my UEGO failing?
As my car warms up at idle, the EUGO slowly creeps from about 13 afr to full scale lean (past 18)
If I blip the throttle, or drive along on part throttle is barely registers on the gauge, occasionally flashes about 16-17.
The car smells like it's running very very rich too, and it's running rough, which suggests to me the ECU is seeing the lean signal and further trying to richen it by pouring in fuel.
On WOT it's fine, and the AFR pops from fulls scale lean to 12-13 where it should be.
Anyone seen this before? It just seems odd that if it's failing, it works ok on WOT but not the rest of the time.
Old Sep 8, 2010 | 02:37 PM
wadzii's Avatar
Banned
you really have to test the sensor..
[media]http://www.youtube.com/watch?v=1mb4VmDd0ao [/media]
thats the best way to test it.
also, if you have exhaust leaks before the sensor it can make it slow.
Old Sep 9, 2010 | 04:25 AM
spectacle's Avatar
Sounds very much like an exhaust leak
Old Sep 9, 2010 | 04:57 AM
MB's Avatar
MB
Member
Thanks guys.
I had seen the UEGO video a few days ago, but haven't got around to testing it yet.
Agree on the leak, nightmare trying to find it though as the whole manifold etc is all insulated!
geekyjerry
Feb 24, 2019 05:19 PM
Metcalfe
Jun 27, 2013 12:34 PM
s2k manic
Jun 19, 2012 02:09 PM
NineBolts
May 24, 2010 08:58 AM
qbmurderer13
Jan 24, 2008 12:18 AM
