N/a tuning software needed?
I just got the AEM series 2 and will be getting an E-tune soon. I believe that Jeff Evans encourages a wideband for E-tunes but my friend had his dyno tunes and he didn't need anything else. He still has all stock sensors and no gauges at all.
I also want a wideband for piece of mind and fine tuning later on.
Do you need a wideband? Nope, it's not needed. Your friend got away with the stock sensors because the tuner most likely used the dyno's wideband and left it in open loop. The AEM ecu does not support the factory narrowband sensor (Haltech does though). In order to gain closed loop o2 control just like the factory ecu you will need a wideband.
SPECIAL-OPS-S2K
Jan 31, 2009 10:21 PM
