New to AEM. Install questions
Hey I was wondering what tools I need to install the following items, and their ease of installation. If you think there is a better sensor I should use for this application feel free to chime in. AEM 1052 emu is taking over for the e-manage blue, a AEM UEGO sensor, and a Omni-Power 2.5 bar MAP sensor.
I know I have to weld a bung on the dp for the UEGO sensor. I am unsure of where to go from there. As how far from the turbo should it be installed. I heard it is supposed to be installed in the 10-2 o clock position to keep the sensor clean.
For the MAP sensor I believe that I am still on the stock sensor. The Omni sensor says plug and play. I know I need to configure the sensor in the AEM software, but is that it? I know some sensors require you to drill another bung and I was wondering if this was the case as well.
Thanks in advance for the help. I just want this done right the first time.
If you are boosted, I would recommend changing the Air temp sensor as well. The OEM Honda one is somewhat slow to react...on NA is ok, but on boosted set ups we go with an aftermarket air temp sensor.
