AEM map sensor
Old Jan 14, 2006 | 09:39 AM
evf2000's Avatar
Default AEM map sensor
Hey all...
I just was wondering if I needed to get the S tuned at a dyno again if I install a higher voltage map sensor or does it correct itself... I am boosting 16 psi so it needs to be done I'm pretty sure.
My mods are below to show what I have, if that helps. Thanks, Rob
Old Jan 23, 2006 | 10:10 AM
tizbad2k's Avatar
you dont need to retune the ecu, what you do need to do is to make sure that the map sensor is calibrated correctly within the aem.
if the map sensor you are using is one of the ones that is built into the wizard you should be all good if you simply select that you have installed a new one. If it is not in the wizard you will have to manually calibrate it. depending on which version of the software you are using this may or may not be possible.
Old Jan 23, 2006 | 02:42 PM
Slows2k's Avatar
Moving to FI
amdaman
May 20, 2015 01:35 AM
jb34304
May 24, 2010 02:26 PM
spoolins2k
Jun 5, 2007 12:24 PM
waytooslow
Apr 24, 2006 08:04 PM
