New Flashpro owner
Old Jul 12, 2010 | 06:13 PM
thesilverbullet's Avatar
Default New Flashpro owner
old rsx-kpro programmer finally got in on the flashpro. see links below for my first datalog. just loaded up the toda calibration and hit the streets. a/f not bad for an out of the box tune...
questions..
1. the WOT lambda table is target a/f values but the ECU still run to the base fuel tables and makes corrections as needed to hit the values in the WOT lambda table?
2. anyone disable the vsa? what happens to vsa light? throttle cut disabled? brake engaugement disabled?
my mods are F5 fujtia cai, jvt header, invidia 70mm tp and single exhaust and now flashpro...
i love the throttle table - sweet...
4th gear pull
http://forums.clubrsx.com/attachment.php?a...41&d=1278986021
3&4th gears
http://forums.clubrsx.com/attachment.php?a...42&d=1278986045
1-4th gear pull
http://forums.clubrsx.com/attachment.php?a...43&d=1278986288
Old Jul 13, 2010 | 08:52 AM
alSpeed2k's Avatar
Congrats on finally getting one! I haven't had much time to play with mine yet.
As for the VSA, check out the FAQ, there's a link to the VSA thread.
Old Jul 13, 2010 | 08:53 AM
alSpeed2k's Avatar
Here's a link to the FAQ: https://www.s2ki.com/forums/index.php?showtopic=757183
Old Jul 13, 2010 | 10:00 AM
crazysupratt's Avatar
glad you finally got the flashpro thesilverbullet
there are a ton of features that I'm sure you will maximize
Old Jul 13, 2010 | 11:22 AM
Gernby's Avatar
Former Sponsor
Disabling VSA works great for me. Everything works normally as far as I can tell, but it won't cut fuel.
I have found no purpose for the WOT lambta tables. They seem to do nothing at all.
Old Jul 13, 2010 | 04:37 PM
thanks guys. i'm going to kill the vsa right now...
disappointing the WOT tables don't work - i suggested something like this years ago (the system should allow the ecu to auto adjust the a/f in both open and closed loop) to hondata years ago for the kpro system. at the time hondata response was that it would not be good if the ecu made bad adjustments during WOT.
Old Jul 13, 2010 | 06:25 PM
Gernby's Avatar
Former Sponsor
I build a self-tuning piggy back ECU years ago that did something like that. However, I still think it's better to just give it a good tune, and let it run in open loop.
Old Jul 14, 2010 | 05:38 PM
probably right. one day i would still love to see the ecu auto adjust the a/f for all conditions including WOT - at lease the ones monitored - IAT, ECT...
Old Jul 16, 2010 | 04:24 PM
scareyourpassenger's Avatar
It still may be worth experimenting with. It seems to do a decent job adjusting quickly to conditions when you trick it into staying closed loop.
Old Jul 16, 2010 | 04:53 PM
Gernby's Avatar
Former Sponsor
If your part throttle tune AND full throttle tune is good, then closed loop at full throttle is less than helpfull. All you need is for closed loop at part throttle to adjust LTFT for humidity, and that will put everything where it needs to be for full throttle.
