Noise from transmission help please.
Hi everyone I have a noise problem while idling from the transmission the only way it will go away is when I press in the clutch pedal. Can anyone please help me?
Nope u have to breakdown ur entire transmission. It's easy to do if u have experience. Just time consuming. Btw it could be either input or output bearing. But if ur already in there I'd replace both. Cheap transmission fluid is the cause and for me it was Honda fluid the cause.
[QUOTE=Singh_snisen;24197899]Nope u have to breakdown ur entire transmission. It's easy to do if u have experience. Just time consuming. Btw it could be either input or output bearing. But if ur already in there I'd replace both. Cheap transmission fluid is the cause and for me it was Honda fluid the cause.[/QUOTE
okay thanks
okay thanks
