Noises from transmission/differential
Old Jul 16, 2017 | 04:03 AM
tom.tom's Avatar
Default Noises from transmission/differential
Guys,
My -00 ap1 with around 85k miles is making these noises and I can't figure out what's causing them. The noise i'm most concerned with is a wobbling/grinding noise which is only present at low speed, from 1 mph to around 30 mph. This noise seems to stick around as long as the car is rolling, no matter if it's in gear, clutch engaged or disengaged, however the noise is most noticeable when acceleration. There is also a whining noise that appears when accelerating. Both the noises can be heard in the attached audio file.
Since the recording I have changed differential fluid and transmission fluid, both of which looked pretty dark. The differential fluid had some metal shavings in the magnet plug. The fluid change somewhat improved the noises but was not a complete cure. I could be wrong but i'm guessing a bad bearing somewhere in the drivetrain, but which one?
Thanks,
Tom
File Type: wav
Old Jul 16, 2017 | 07:19 AM
deception9's Avatar
i'd ask billman, i'm sure he could pin point that with reasonable accuracy.
that does not sound good though. transmission tail shaft bearing?
Old Jul 19, 2017 | 08:47 AM
jyeung528's Avatar
hard to tell, something wrong.
Old Jul 25, 2017 | 09:21 PM
StrokerSi's Avatar
See this thread:
https://www.s2ki.com/forums/s2000-un.../#post22852370
austincrx
Feb 1, 2013 07:22 PM
apme123
Nov 20, 2011 03:17 PM
DERF
Aug 16, 2006 03:50 PM
Vixen
Apr 13, 2004 07:40 AM
n155a21
Mar 17, 2004 06:11 PM
