Non-functioning sensors/components w/Kpro
Old Apr 16, 2011 | 03:40 PM
hybridsol's Avatar
Default Non-functioning sensors/components w/Kpro
Not being able to find a comprehensive list, what does Kpro (not Flash pro) no longer use/read/operate/changed on a AP1?
Here's what I have surmized so far:
  1. Air pump- all sensors/outputs not used
  2. Intake Cam sensor- not read/not used
  3. Exhaust Cam sensor- re-wire to different ECU location- stock wiring not used
  4. Crank sensor- re-wire to different ECU location- stock wiring not used
  5. Secondary O2 sensor- not read/not used
  6. ELD sensor- Read as option for different use
  7. Purge solenoid EVAP- Used for boost control/NO2 or not used
  8. Power steering pressure switch- added input (obvoiusly we don't have PS)
  9. VTEC pressure switch- ECU switch input/not used
  10. A/C pressure switch- stock wired to VTEC pressure switch on PRA ECU
Anything else? Eventually, I'd like to clean up the wiring/remove stuff that's not needed...
Thanks!
Old May 8, 2011 | 05:25 AM
03AP1's Avatar
I'd like to know this info as well..
Will cruise control still work w/Kpro installed on 00-05's?
Old May 8, 2011 | 10:25 AM
DFWs2k's Avatar
Yes
ZachS45
Feb 13, 2018 08:35 AM
crisskro
Oct 9, 2013 07:46 AM
lotus7racer
May 25, 2008 04:57 AM
ack5252
Feb 19, 2008 12:50 PM
C6400hp
May 6, 2005 04:53 AM
