not showing water temp
Old Jun 10, 2010 | 06:47 PM
JuicedS2K's Avatar
Default not showing water temp
I'm on the screen where it shows water temp , speed, rpm, boost, ignition, ect, the rpm tach and coolant temp meter don't budge at all. The other meters work.
Basically, why isn't the coolant meter moving?
Old Jun 10, 2010 | 07:46 PM
Little_AP1_S2K's Avatar
just thinkin, but dont the 1052u not work with the coolant temp? i remember mine did not and jeff evan hooked it up so my serial gauges did read it. might be something within the system you have to play around with. i'l ask my brother he tuned his by him self so he might know.
Old Jun 11, 2010 | 06:16 AM
Gernby's Avatar
Former Sponsor
IIRC, the ECT gauge on the dash cluster doesn't work with the EMS, but I believe you can get a fix from modifry.com
Old Jun 11, 2010 | 08:41 AM
JuicedS2K's Avatar
I know, I just want the one on my lap top to work when its connected while I'm driving the car!
Old Jun 16, 2010 | 08:10 PM
aresk3b's Avatar
is your coolant sensor configured properly on Aem?
Old Jun 17, 2010 | 05:34 AM
JuicedS2K's Avatar
I was not on the main parameter screen, I thought the screen with all the big fancy gauges was the main parameter screen!
Old Jun 29, 2010 | 06:11 AM
maluch's Avatar
make sure that the ECT does display correctly in the parameters window. if it does not then you screwed up the default template which doesn't influence anything in terms of engine operation. I find the template cluster very useless anyway.
riceball777
Aug 8, 2013 07:45 PM
abroke1
Jun 16, 2013 05:50 PM
JoeyBalls
Jun 8, 2010 09:27 AM
Kwando
Sep 17, 2009 07:23 PM
Venomous S
Jul 29, 2005 04:19 PM
