PLX
Old Oct 25, 2013 | 11:48 PM
Capitan29's Avatar
Default PLX
Im currently doing a turbo build and want to know. IF the plx gauge will work with my aem ems 2 and if it does which kind is better
Old Oct 27, 2013 | 04:58 AM
timg's Avatar
Which PLX gauge? The SM-AFR? If so, the answer is yes, but the output would be analog only.
Why not use an AEM Wideband Failsafe? You can wire it digitally to the EMS using the AEMnet and get a lot more functionality.
http://www.aemelectronics.com/wideba...safe-gauge-84/
http://www.aemelectronics.com/Images...%2030-4900.pdf
Tim
Old Oct 31, 2013 | 08:26 PM
P-CarDriver's Avatar
I have a PLX sensor wired into my AEM EMS. I use the AEM multi-gauge though. I dont see why it wouldnt work, its just a signal wire and you input the resistance or something like that into the EMS software. Im pretty sure almost any wideband can provide the EMS with the data it needs. I remember there being a dropdown box with multiple manufacturers and a custom drop down where you input parameters for whatever sensor your using.
skool u
Jun 23, 2010 10:46 PM
Spec_Ops2087
Aug 26, 2007 09:41 PM
PRS2K
Aug 2, 2006 07:54 AM
S9Krpm
Jul 18, 2006 07:29 PM
regmilla
Oct 6, 2005 05:47 PM
